loose motor mount on 02' viper
devvy2
SW Wisconsin
I haven't had time to buy a service manual yet. Anyone know what the motor mount bolts should be torqued to. The front pto side bracket came loose, sheared the bolt off in the block. Could locktite be used?
SRX motor mount
Get an SRX motor mount to put in this location. Get it from Rich Motorsports....they are cheap. It uses three bolts to hold it to the case instead of two and you will never have this problem again. Why Yamaha ever redesigned that motor mount is beyond me.
Madmatt
They use the 2 bolts because the electric starter bolts in the third, if you don't have electric start always use the srx mount, if you have ES you can modify the starter.
