spider
- Oct 11, 2003
What do you use to clean the clutches? I used Acetone but I can't get the dark/white corrosion off the plates. It maybe from salt. Please let me know what I could use or do.
rx1mtn
I always use "brake clean" and then a fine steel wool to polish the faces of the clutch to get the corrosion and belt resido off.
skidooboy
red or grey scotch brite scuff pads from the auto paint supply store (3m) and an acetone based cleaner. i acutally have a clutch cleaning solution i bought from powermad. but, brake clean, carb clean and electrical contact cleaner should work just fine. you need to rough up the surface of the sheeves to get better belt adhesion. keeps the clutches consistant. ski
what i do some might not agree with but i start my machine with the belt off and take a peice of green or grey scotchbrite and being very careful polish the clutch with it spinning, that way you'll not get any high or low spots
skidooboy
flyby, whos traction brackets are on your srx? the viper oem ones or another? did you have alot of modding to do for fit? got any up close pics showing the mounting and what it looks like from the sides? very interested. ski
