phazer airbox on exciter?
Exciter89
Minnesota
anyone know if i'll have problems using a phazer airbox on a 570 exciter? i have a bender cold air setup for a phazer but it won't fit with the exciter airbox. will the smaller phazer airbox cause any problems? or should i just modify the phazer cold air intake to fit the exciter box? also is ther supposed to be foam or something in the airbox? i cleaned out a giant mouse nest from the airbox and there was no foam..
i'm going to try fitting the phazer airbox on the exciter, i honestly don't see any problems the smaller airbox will make. unthere is something i'm missing? as long as i watch my plugs i should be fine. i'm jetted up for the PSI pipe anyways.
