M10 Torque Arm ? for you
xsivhp
Eau Claire, WI
Do these look correct to those of you that have experience with the M10?
Thanks,
xs
yes, they do. dont use those holes though. use the rear hole and drill a new center hole. make it line up with the handlebar hoop that bolts to the side of the tunnel. if you mount it in these 8 shaped holes, they can slide on a hard hit.
good luck
