linux gallery imbedding pictures
JeepTherapy
Negaunee
I use linux gallery to index and store my pictures on a linux web server. I have been having some issues embedding pictures. I have been using the syntax "
" and this is how it comes out;
main.php
Prior to the web server being rebuilt, relocated and redesigned it worked fine. Now it just shows the image as a link. The path I am using is the actual path to the photo on the server. Is there something in my path that is causing it to be blocked? Also, it seems to work fine on some forums. Not this one though. Would sure appreciate any insight you can give.
I am not sure on that one. Normally the img link has to have a gif or jpg image in order for it took work. I am sure it maybe a security thing on the forums as I know this one is set high.
