yamidork
- Nov 6, 2005
putting a 700 sx motor together,need advice on pistons to use.stock or wisco . i run SLP pipes so it is running 8800-8900. had guys tell me run stock,had guys tell me run wisco. what do ya think.
SRX7
Stock, no if ands or buts.
Well I thinck you are goin to have the same problems here, some guys will say stock and some guys will say Wiseco....For me I will do stock ones just like SRX7 said...
That is 2 for the stockers and 0 for the Wiseco...
Nick
Nick
VenomMod
I'm in the process of rebuilding my motor, and I will only put Yamaha Pistons in. I can guarantee that more will chime in and tell ya to use stockers.
Dave_Vmax600
only go wiseco when you go big bore....
SWEDE
I would lean towards oem myself, but either are fine the wisecos just have to be setup differently.Most guys that I know that had troubles with aftermarket just slapped them in and did'nt check clearances and such.Thats a certain recipe for troubles in my book.
OEM, Yamaha!!!!!
6-0 OEM in the lead!!!!!
weiscos or spi's never use oem for replacements
NOT Just trying to spoof everyone. oem is the only way to go. Maxdlx
Yammerhead
I've always used OEM. Wiesco's need to be set up differently than a Yammie piston. I'm sure they can work fine but you have to know what you are doing with your clearances.
The OEM's work better for dummies like myself.
cannon3731
I use Yamaha OEM for every rebuild.
OEM on my rebuild.
Tod
Tod
deeppowder
Used Wiseco's once, OEM ever since.
