mm700sleder
i have a 2003 viper and i want to know what weights, springs, helix, ect. i should use to hook this puppy up the best, and get a nasty holeshot. is is primarily a trail sled but i want it to preform in drag races. it has a one inch camoplast track on it with the studs that screw into the lugs on the track and also has a marginal snow wheel kit, and i have ajustable transfer rods on it. please give me a detailed parts list if you can, and if you have the parts, i might be interested
triple
mm700sleder said:i have a 2003 viper and i want to know what weights, springs, helix, ect. i should use to hook this puppy up the best, and get a nasty holeshot. is is primarily a trail sled but i want it to preform in drag races. it has a one inch camoplast track on it with the studs that screw into the lugs on the track and also has a marginal snow wheel kit, and i have ajustable transfer rods on it. please give me a detailed parts list if you can, and if you have the parts, i might be interested
Click on TY Tech. Alot of clutching setups for your sled on there!!!
