Drive Axle Torque Specs
braindead1684
Near Flint Michigan
Does anyone know the correct Torque specs for the bolts on the drive axle on my 96 vmax xt 600. Looked on the tech pages could have sworn i had seen it before but couldn't find it.
chain case bolts are short ones 7.1 ft-lbs, long ones 15 ft-lbs
and 17 ft-lbs on the speedo bolts
be carefull tho, somtimes not sure on yammie specs,dont
want to strip 'em out.
Is that for the the house and actual case.
I need those but also need the ones for the nut on the end of the drive axle and the bolt that goes in the shaft where it comes into the chaincase.
yes thatt should be for all the case bolts, use 15 for case to frame.
lower sprocket is 31,looking for the nut.........
ok not seeing a whole lot here but i see drive sprocket and driven sprocket
so i'm going to say it's drive, and that one is 36(the nut).
