tedgoesfast
my sled yesterday every time i turned sharpleft it would pull the rpm up to 4000 rpm somewhere it is pulling throttle cable tighter has anyone seen this before i will have to pull handle bar cover off and inspect
mod-it
Not sure how the air box is on your sled, but I've seen the gas and oil cables get pulled from improper routing around the air box before. It seems odd that it would just start doing this, have you done anything to it recently?
tedgoesfast
nop ill ive done is due some clutching gearing installed reed spacers and removed layer off head gasket but worked fine after ill pull it apart and see cable must be getting pulled somhow
check your routing, those 97's are noted for that, they route over the air box and if not perfect will do what you said, also loosen the throttle cable up as loose as possible, make sure the cable is seated firmly in the carb bracket holder
