jayman54
i rolled it the other weekend and took a big chunk outta the windshield.. with a little creativity with tin snips i made it look custom till i get a new one... my one plastic ski it bent up and throws snow like a b*tch i gotta get a new set and i repaced teh front bumper but cant get that damn paint marker letters offa it!!
If you took a green dish scrubbing pad to the paint on the bumper would that maybe get it off? Some emery cloth maybe? Last:. Your not afraid to spray paint it black are you? Its been a long time since I took a bumper off but possibly a dumb question, can you bolt in on bith the paint marks facing the ground?
I would go with a blue Cobra mid height windshield for it. Make sure you get the one for a single bulb head-light sled.
8vo fan
Carb clean takes it off. The good stuff not the cheap crap. Soak a spot on a rag, It will take a little scrubbing.
T.S.U.Filmz
try pulling the wear bar off the ski and puting a new one on might just be a bent bar. that is all it looks like to me i had to do that once
TopGunnSrx
Ive heard soaking your ski in hot water will make it take its original shape again. I would try that before buyin new ones
How did u happen to roll it,caught an icy spot or just lost control due to speed or what?
jayman54
i climbed a big dirt hill where they were building houses... there was a pathway up the center it went gradually up then sloped back down the other side.. so i went up then back down but cause it was night i didnt notice that they had be diggin from the one side so it was a sheer drop off about 10-12 ft i had no studs and i coudnt stop the sled from sliding so i bailed but ended following it... it landed nose first then landed upside down.. thank god there was alot of snow i thought my shround was fu*ked but its all goos...lol scared the hell outta me a lesson learned i guess...lol
JeepTherapy
Carb cleaner will leave stains if you just spray it on there. It also will melt craftsman screw driver handles
I would try lacquer thinner in an inconspicuous spot. Did you already try WD40?
Sounds like it was a scary adventure. Also looks like it took it quite well.
jayman54
i tried paint thinner and it wouldnt even touch it
