Looking for a Heel Clicker clutch kit, what and where to get it ?
Raced Guy
WI
Ive been reasearching and have come to the conclusion that the heel clicker clutch kit sounds like the best. What exactly do i need to order for the entire kit, and where is the best place to get it. I dont know alot about clutching so any good help is appreciated. If it helps the sled has a modded silencer, shaved head, reed spacers,and when i bought it i was told it has a different helix machined on secondary. :winterrul
If you don,t know anything about clutching or don,t have a friend that knows something.....i recommend you don,t tackle tuning these components. this is not something u just buy & bolt in. It requires testing & tuning to get the right rpm,s with out slipping or overgripping the belt. buy aaens clutching handbook & read it 50 or 60 times to get a grasp on what is going on with your clutches.If your srx is revving 84-8500 rpm at wot your doing just fine.
Turk,we all have to start somewhere.I did..you did.By the way MERRY CHRISTMAS,I didn't get a card from you this year with all the purchases I 've made off you..don't I get a card...a gift card even....lol HAPPY NEW YEAR TO!!!
I am not clueless its just this isnt a cake walk for me. MY 99sx 600 was already clutched and dialed in perfect so i never had to tinker with it. I also had an indy 500 but never touched anything on that. Im a mechanic so i should be a able to pick it up pretty quick, just looking for a good solid direction to start towards i guess.
RACED GUY, HEEL CLICKERS ARE AWSOME NO DOUBT, AND LIKE MIKE SAID, THERE IS TUNEING LEVEL WITH THESE. FIRST THING RIGHT OFF THE BAT YOU HAVE TO BUY A GRAM SCALE. THAN MAKE SHURE YOU HAVE ALL STUFF FOR PULLING CLUTCH ON AND OFF ALOT ( puller, spring compressior, like i said gram scale etc) BUT EXPECT GREAT PERFORMANCE WHEN THEIR DIALED. I ASSUME THIS IS FOR A 01 SRX ? 3:16 (yammie tony)
I ordered a kit from Rich Motorsperts for my viper. I'm not sure about an SRX set up. Its not that hard to install but it will take some testing to get it where you want it. Check the tech section and just search the posts to get a baseline set up.
I see we have the same taste in trucks. ;)!
40/10Y heelclickers with red hc primary spring
52/42 helix or something close
green yamaha secondary spring
This was my starting point;
40-10YB
4-5 in heel
5-6 in tip
50-40 Dalton
Green spring at 70
Red primary spring
Tweeked it from there ;)!
Awsome, thanks for the help guys. I cant wait to get it done and start to get it dialed in. Justaviper yes we do. How do you like the Max, i love mine it gets up a moves for a truck.
Turk will the same set up that you told raced guy for his srx 700 work on a srx 600? just wondering looking for a starting point thanks.
SRX 600 won,t pull the same clutching as a 700. A helix about a 46/40 will work with a 600 SRX. You also should get rid of the 16mm rollers & got to 15.6 or 15mm rollers.
Turk - I've never changed from stock rollers - do they do anything other than lower the engagement?? - and if you do change them, do they effect any other area of your clutching? (still learning) LOL!!
different size clutch roller affect the whole shift. A smaller roller will lower engagement and also lower rpms. They make the weight act heavier/lighter in the way that it tucks the weight in the spider. With bigger rollers, your weights are going to be tucked tighter (more vertical) therefore will require more force to shift out. It's the opposite with smaller rollers.
Turk said:
xtc gotta be piped to pull that clutching.
Nope Stock exhaust.Cases and cylinders are ported,pistons mododified by MrViperand is blown f7's away that was with 8dn's.This year I modified the intake transfers to accept vmax 4 v force reeds and put the heel clicker in with quite a bit of tip weight?This baby is amking some hp!
