Wanted Circle M Injectors
deanosmod
New York
Hello,
I'm looking for a set of circle m injectors for a 440 motor. I think there 42's. I'll also need the fuel pumps and primer bulb. Thanks Dean-o
you can get 42mm throttle bodies and 45mm bodies.
a set of 44mm mikunis will flow more fuel/air than the circle M set up will and they are much more easy to tune and set up. The mikunis are also more forgiving when you make a mistake.
Thanks Sno Pro. I'm just putting them on my show sled. I'm running 45's on my pro stock drag sled with Delaughters new pipes. Both 77 srx's. Thanks Dean-o
45's are pretty small for those pipes but Dave would have told ya that. Tuned right, low end and midrange would be wild tho!
