YamahaXtreme
I just took the power vavles out and I numbered them 1 2 and 3 I was just wondering if it mattered if I didnt put the same vavles back in the right order? Im guessing it doesnt make a difference just wanted to make sure.. Also you guys have any tips for cleaning? My dealer told me to be careful and not to chip the finish off or that could cause issues.. He actually had me replace one last year that looked perfect me.
it doesnt matter in the order, a cleaning tip is soak them in solvent overnight and then use a straight blade razor blade and it will clean them right off. The finish is hard anodizing and is pretty tuff as long as you dont gouge the surface.
If your in a hurry use Air craft paint stripper,very strong stuff and will clean
the valve like new in a few applications, but will not hurt the coating.
after cleaning however you do it make sure you adjust them,very importaint, try a search lots of info on PV's here.
YamahaXtreme
TY guys
sure, good luck!!!!
