Phazer oil leak
Tank1
Oregon
I have a 96 Phazer that has an oil leak. It appears to be coming from somewhere behind the primary clutch. Its nothing major just enough to form drips on the trailer floor when I am not riding. Is there seal or something back behind the primary that could be leaking. I do not want this oil to contaminate the belt. Thanks in advance.
the oil pump drives on that side of the crank ive owned 4 phazers never seen this before i would pull the clutch and inspect the oil pump housing to see were its leaking oil leaks never get better only worse
you could try changing #14, but like said above pull the clutch and have
a look
