chevymax
Found a set used h/c but the guy knows nothing about them,and neither do I.I will post some pics.If anyone can tell me if these are the right ones to put in a piped viper.They are coming out of a stock viper and He says they are about a year old.Any help would be great.
Yep them are the one's does he have a red spring though?
Yamiggod has a spring in the classafieds otherwise.
chevymax
No red spring.I will have to find one.
Thanks for info.
Thanks for info.
progold
Sorry To But In On Your Thread Chevymax But You Said Those Heelclickers Came Out Of A Stock Viper Can Anyone Tell Me If That Would Be An Aggressive Trail Kit Looking For A Setup For My 02 Viper.
Tahnks Progold
Tahnks Progold
YAMMIEGOD3:16
I HAVE RED SPRING, SENT YA INFO. 3:16 (yammie tony)
progold heel clickers are very aggressive on the trail.
chevymax
Thanks for the spring Tony.
Where can I find a 50/40 helix and a green spring.
YAMMIEGOD3:16
OK, COOL !! GLAD SPRING MADE IT TO YA. 3:16 (yammie tony)
yes, those ones bolt right in and dont require any notching of the sheave.
chevymax said:Thanks for the spring Tony.
I have a 50/40 in my piped viper. I've tried moving waight around to gain some mph and rpm, but no luck. Just a little heads up on the 50/40. It may work for you depending on what your trying to achieve. I'm going to try a shallower finish angle and see if i can get some more speed out of this thing. It goes like hell till 95 mph and thats it.
justaviper, 50/40 works excellant, its probally your weight placement and spring tension used in the rear, you can get plenty of speed from a 50/40, with a 40 finish youll run less tip weight then that of a shallower finsh, however in a piped viper you wont be running tip weight anyways at 9000+ rpm, so loading it some with the helix finsih will work good.
If you post your set up I may be able to help tweak it for you.
I lost the instruction sheet so i'm not sure on the waight of the bolts and washers. Right now I have the small bolt with 6 washers in the heel to get the engagement at 4200 with 50mm rollers. Long bolt with 2 flat washers and 1 lock washer in the middle, tip empty. Red H/C primary, 50/40, green secondary at 70. I've tried less waight in the middle with tip empty. More and less waight in the tip with middle empty. I'm starting to think because its a 136 ripsaw track that thats all this sled will do. I was thinking of trying the secondary at 80 because i get a slight bog in the deep snow. I'm afraid if i do i'll have no top end speed at all. Then again it may raise the rpm enough to pull more mph? It seems no matter what i do i can only get 8500 rpm.
I replaced the big middle bolt with a small one with 1 lock washer. Set the helix at 80. 8700 rpm and 110mph in about 1/4 mile. It was still climbing but i had no room left. Its amazing the difference a few slight adjustments make. Now i need anti ratchet drivers LOL. The 50/40 does work good, it just took me a while to get it set up. I think i'm going to try a 50/36 though just to see if there's any gain.
