Classic SRX
I was riding along at 1/4 to 1/3 throttle at about 60km/h - maybe 5000 RPM(clear day, just about freezing) and the sled quit on me. The plugs are a chocolate brown and it seems to have spark - at least when they are grounded on an engine stud - I can't be sure they're firing under compression. It seems to be getting fuel. I've tried priming with fuel through the plug hole - it'll kick, but won't start. I've got some spares parts that came with the sled, but I can't be sure they're good. From the spares, I replaced the external coil and the CDI box, but no change. The carbs are butterfly's from an '87 with stock jetting. I had put about 30km (20miles) on today before this happened and the sled was working fine.
My next step is to open it up and look at the stator. I've got two spares, but again, I can't be sure either is good.
Anyone have any other ideas? Or timing specs (I don't have my manual with me - it's on the missing list right now)? Any input is appreciated!
Angus
Angus
tedgoesfast
have you done a compression test
Classic SRX
No, but there's lots there when you pull it over.
YAMMIEGOD3:16
ANGUS, SOUNDS LIKE COIL ON STATOR. THOSE ARE VERY CHANGABLE AND CAN BE TESTED. I HAVE SPEC IF YA NEED IT. ALSO I AM SHURE VERY AVAILABLE FROM YAMAHA. 3:16 (yammie tony)
Classic SRX
Thanks Tony. Specs would be great if you've got 'em. I'm going to try the spare stators I've got today and see where that gets me.
A.
A.
YAMMIEGOD3:16
LET ME KNOW IF YA NEED COIL SPECS FOR TESTING. 3:16 (yammie tony)
Classic SRX
My uncle was good enough to do a stator swap for me over the weekend (sled is at home, and I'm 3 1/2 hrs away). He tried the two spare stators that I've got, and no luck getting it started. He also tried several combinations between the 3 stators and 2 CDI boxes.
Compression test is next on the agenda, but pulling it over, it feels plenty strong. Even if one side was bad, it should still run on one cyl. What's the chances of both going bad at once?
I've got a spare wiring harness to try next. My thought is if there is a broken wire or bad connector in the harness, I should get full fire or none at all shouldn't I?
Any more suggestions Tony?
A.
A.
YAMMIEGOD3:16
ANGUS WOW. LETS START AT THE BASIC, YOU HAVE GOOD SPARK. 3:16 (yammie tony)
Classic SRX
Well, I have some spark. If it was good spark, it should fire a few times on the fuel poured in through the plug hole shouldn't it? Sometimes I get one kick on the prime, and othertimes nothing at all. That's why I was wondering if the spark is too weak under compression.
I should also note that this was an elect start sled, but I removed the battery & starter in the fall (to shed some pounds). As far as I can tell, all the wiring at that end was properly tied off, but it's got me wondering now...
A.
A.
YAMMIEGOD3:16
YES I AGREE !! GOOD SPARK THAT SLED SHOULD FIRE WITH GAS POURED IN PLUG HOLE. YOU HAVE TO START THERE. I DOUBT ITS COMPRESSION WHERE THE MOTOR IS HURT. YOU GOT SOMETHING ELECTRICLY GOING ON. YOU REPLACE PLUG BOOTS AND OUTSIDE COIL ? YOU NEED TO PROBLEY CHECK ALL WIRING. MAKE SHURE THAT WIRING FROM THE ELECTRIC START AIN,T CAUSEING THIS. MIGHT HAVE HOT WIRE GROUNDING OUT YOUR INGINTION. MIGHT BE ACTING LIKE A SHORTED OUT SYSTEM. 3:16 (yammie tony)
Classic SRX
Yeah Tony, I swapped out the external coil - was one of the first things I did. I'll go through the wiring harness next.
A.
A.
YAMMIEGOD3:16
HOW ABOUT POSSIBLE TETHER, ENGINE KILL BUTTON, OR KEY SWITCH. JUST THROWING THINGS OUT THERE. 3:16 (yammie tony)
Classic SRX
Yeah, all possibilities, and things I'll have a look at.
A.
A.
YAMMIEGOD3:16
ANGUS, LET ME KNOW ON THIS. VERY INRESTRED TO SEE WHAT THIS IS. 3:16 (yammie tony)
Classic SRX
I sure will Tony. I'm not sure how much more testing my uncle will do for me (his young fella beat up one of their sleds the other night, so he's gotta get that up and running), so I've got to get home to look at it myself. Not sure if it will happen this weekend, but if not, it'll be next. I'll keep you in the loop! Thanks for the help.
Angus
Angus
LoneViper
If you haven't done so, check the ground maybe run a new one from the engine to the sled frame.
Classic SRX
Thanks LV - I'll look at that when I'm going through the rest of the wiring.
