chevymax
I would like to know if anyone can tell me the lug hieght is on a 690 9893 camoplast track.I have tried doing some searches on it with no luck.I believe it is a discontinued track and no one keeps their old books to look it up.I called camoplast and they are out until the 2nd.
Any help would be great.
nitris223
I just looked through a 96,99,2000,01,02,05 catalog and none of those numbers match. The catalogs use their own part numbers. Any numbers after 9893. Or any other numbers.
chevymax
No
Only #'s are 690 9893 All I know is it is a older track and it is a cone style track.The guy says it is 1 1/8 track.I have never seen that size.I want to put it on a viper and stud it.I don't want to change drivers so I need to know what lug height it is.
The #'s are right on the track.The only I can think of is it is a oem track and those might be oem #'s
Thanks for looking.Maybe someone else will know.
tedgoesfast
i think they came on the older rx1 i think a 1 and a eighth stud should be fine
Yama49601
The only info I can find for that part number is a 136" 1.187" lug that weighs 40 pounds clipped every third. Best profile for handling and top trail speed is what it says.
chevymax
Where did you find that info.
Yama49601
This auction , the only other place I could find that number is in a Recreation Supply catalog.
nitris223
I just put a 1.250 track on a 2002 SXR 600 and there is lots of room. I do have the rad guards removed though. I think you can put a 1.5" track on a viper and still be good.
richierich
yes thats a 136 x 1.187" track.
