secondary clutch help
overpowered srx
NORTHERN, IL
how do u shim the secondary if the belt sits 1/8 under the top of the sheaves??? sled keeps overrevving 2 9500 this is on a 99 sxr 700 with simons cpr pipes and bender clutching
there are small bolts behind the secondary with washers. Adding a washer will allow the secondary to close more. Have you ever serviced the clutch....cleaned, change cam shoes, replace spring or bushings. There could be somthing in the clutch that is causing your problem.
