Help with Sno Sport - carb / fuel issues
bobweiser
UP of Michigan
I am having some issues with my '91 Sno Sport. Seems to run ok but when I let it drop down to an idle it dies or starts to die. I give it some gas, bogs slightly but then runs out good. I cleaned the carb but still not ruling that out. Also was thinking it could be the fuel pump.
Is there any other carbs out there that would work?
Make sure FP is working, clean carb again blow everything out with air,check float hight spec..check your fuel screw,set to where it needs to be..etc......
