SRX roller secondary problem
jdmt49
Minnesota
I have a Advantage roller secondary that is twisting my spring 180 degrees(over time) so that the spring ends are not opposite anymore like they are supposed to be, instead they are ending up in a straight line and loosing all the pre-tension. This has happened to 2-springs one silver one green...I'm confused any idea's...I would call the Advantage but I think they went out of business, Thanks in advance.
probably the best roller secondary around for a yamaha. i use them on all my sleds. i've never had a problem with any of them. are you winding the cap & helix in the correct direction?? ulmer racing sells them last i heard & would be able to help you out.
bob
I have been using em since about 1999.Never ever seen that happen.Make sure you tighten em clockwise when installing the spring.
