braindead1684
Finally got the suspension back together, mostly.
Having some difficulty lineing up the plates in the middle, (3hole plates) so that they are in the same position in on the shaft so i can mount it up in the tunnel, i don't think i can tighten the bolts (on the shaft) with it in the tunnel
Line up the plates on the garage floor and then tighten the main shaft down to lock the plates in the same locations. The 3 bole hole plates are a PITA use a punch or a screw driver help align the holes to put the bolts in. This is what I did when I had one. T
