95 vmax 500
blue missile
bucksport maine
what is the oil pump cable adjustment spec for this sled. it seems to be huge on this like over an inch of gap and i know others are only 20 - 22 mm.
On a '95 vm you just line up the marks on the oil pump housing like in the link fleet man posted for you, thats all thats too it.
but before doing that, do this stuff(in order);
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is down at the carb rack)
3rd- then adjust your oil pump..
