rob3b
02 Viper ER 14,000km
Should there be any play on the starter gear? There is about 1mm play between the gear and the clutch.
When the sled idles there is a loud rattle coming from the starter gear and fix primary clutch sleave. Once over 20 Km/hr the noise is gone.
it is supose to be tight, pull the clutch and see what is up
There are 6 little torx screws that came loose on me already this year. Tighten them up.
rancidjo
i had mine come loose before...a little bit of loctite will help
use # 642 loctite go your dealer and see the mechs in back they will have some it came in a recal parts on the old starter gears that we had to change
Snowsnake
Mine also came loose 3 or 4 years ago.Used loctite and snugged them up and no problem since.
