01&02SRX
I am looking for some input on some reasonably priced, and not too involved performance upgrades for an SRX 01 and 02. clutching, etc
Try putting on some HeelClicker weights and tune from there.That is what I have done and almost got it to where I want it in little time compared to the old weights with drilling and pounding in them rivets.Just make sure your clutches are in good shape,centered and offset set properly .
marty f
clutching
advantedge helix 48/40, green secondary spring wrappped at 60,4.5 gram rivets outer weight on primary!!!!!!
this will give you one heck of a boost in acceleration and top end
*xke*
Gears?
Marty f;
What gears to go with the clutch setup?
Marty f;
*xke*
marty f said:advantedge helix 48/40, green secondary spring wrappped at 60,4.5 gram rivets outer weight on primary!!!!!!
Skidooslayer687
stock ones work good
KatahdinLodge
proven setup
Pretty low buck easy kit that works.
-stock weights with 4.5 gram rivets in both holes
-yamaha white/white/white primary spring
-51/43 yamaha helix (stock for 4-stroke 4cyl)
-yamaha green secondary spring set at 70 deg
may need to add or subtract some wrap to secondary depending on conditions/traction
trust me it WORKS!!!!
