What are the differences in the GTY-R skis? I checked part numbers for the ski bottoms and saddles and they are all different between the 98 and 00 as well as the mountain max and SRX. I have a 98 SRX and want replace the ski bottoms but would like something more agressive and/or wider. Does anyone know which bottoms will bolt to the 98 saddle that will give me what I want? I was thinking the 00' mountain max ones. Thanks!!
yes as long it has the alum block that bolts to the ski
Thanks! Do some of the skis have different keels?
no the srx and the mt are the same the oly difference is 4.5 to 5.5 the keels are the same unless you go to saddle less yamaha skis then there are different hope this helps
