ESA class rules?
valin
Val Caron, Ontario
I am having trouble finding the ESA class rules for the ESA Open Lakeracer 0-1200cc class. All I have been able to find is this:
Open 0 – 1200cc - > 700lbs. (625lbs. twin)
Open 1201+ cc - > 750lbs. (675lbs. twin)
- All snowmobiles must:
- meet weight minimum for cc class
- meet cc maximum for class
- must be full body OEM type chassis. NO lay downs or “open mods” allowed
- Material substitutions allowed for body and suspension
- Any cylinder, head, carburetor, throttle body, crank-shaft may be modified or replaced
- Any suspension allowed
- Any ignition allowed
- All engines must be normally aspirated, NO turbos, superchargers or N.O.S.
- All ISR Improved Stock safety rules apply
- Open cc crank case may be modified or replaced
I have quite a few questions.
- What are the track limitations?
- What are the ski limitations?
- Are you able to remove guages? If not, can the guages be replaced? (ie. remove tach and replace with a Digitron?)
- Do you have to have working head/tail lights?
- Are rolled chaincases allowed, if so, how far can they be moved?
- Can you run titanium drive/jackshafts?
- Are open stingers allowed?
