T.S.U.Filmz
What do i need to do to get them to fit? Do i need to get a biger sway bar? The trailing arm wont go down enough to bolt them on
On my sx I took out the brackets where the stock ones bolt on just install the shocks to the bulckhead frame....I used some spacers and washers....The way I did it you don't get to make the front end wider...I can send you a pic later and you can see it....
Don't forget to send me a pic of the skid....
Nick
Nick
bluewho
Try unbolting the sway bar than install shocks.It is a little bit of a struggle with stock rods,the links at the ends of the sway bar should be shortend to fit properly.
T.S.U.Filmz
i will try that out thanks
YAMAHIZAL700
Also take all the preload out of the shock so you have some room to work with. I have viper shocks on mine and i flipped the shocks upside down and made myelf a spacer for the viper style mount so it would fit snugly to the trailing arm. Work great for over two years now
kingtigg
do either of you have pictures of your shocks installed?
Thanks!
Thanks!
