No spark on 07 bravo
ted solomon
Alaska ,Ft.Yukon
I have a 2007 bravo long track with 775 miles on it .
Ok my problem is that i was driving down the road with this sled and then all of a sudden it started sputtering, I thought it was running out of gas in one of the tanks so i switched the tank over to reserve made it another 100 yds and it just stopped.
Called the place i bought it from they said it might be a coil, so I purchased a coil and still no spark. I would take it to the dealer but it would cost me $400 to ship it out. Is there a way to test the cdi ? Before all this happened the starter vibrated off and one of the bolts hit the fan and broke some fins off. Any help to this head ache would be appreciated. :o|
did you try bypassing the tor's?
then you can check harness for rub throughs under the motor or a loose plug. after that it might be cdi time.
you can test the stator but not the cdi. You will need to call the dealer or someone may have the specs for the stator on here
just recieved my stator back and their was nothing wrong with it. they sent me a carberator switch so i'm going to check that out if that doesn't work, i'll send the whole machine back and get a refund minus damages.
