Can i just swap the headlights on my sled? I understand in order to have the dual lights you have to change a lot of things, I am just going for the looks of it.. so any info would be good.
fleet man
basically if you have two headlamps now you are drawing twice the amperage as a single headlamp. I guess you would need to check the output and see if it will handle the extra load.
I wouldnt be using 2 bulbs, I would only have one hooked up. I just like the look of the dual bulbs...
racerdan
There is a post here that someone only plugged in one headlight and said that it was better than his old single system.
u will need to change windshield and the guage pod i think
