ARTICANIMAL2
can you use the boost bootle and reed spacers on the srx?and if so what performance gains would you get?thanks
Yama49601
I'm pretty sure you can use the reed spacers on an SRX too but I'm not positive. I've seen sites that say they fit so must be... It says for the reed spacers: "GAINS UP TO 3HP ON SOME MODELS".
9801srx
you can buy reed spacers for srx's but i don't think there is any benifit since the reed stoppers do not block the boost port in a srx like in a non pv triple. the boost bottle i,am not to sure about but i think it only helps at lower rpm's to get rid of the low rpm bable that the single pipe sleds have.some one else might have a more definant answer.
