NEED HELP!!!!!2001 srx 7
2001SRX=Fast
Manitoba,Canada
i got a 2001 srx 7 here's the story. when you pin it off the line it revs to 8500 then bogs down to 7000 i changed the bushings in the secondary... what else to do???? HELP ME PLEASE....
Did this problem start immediately after the bushing change on the secondary? If so, check the wrap on your secondary spring.
Check your primary clutch spring. It can be hard to tell if they are broken unless you take it apart and look at it.
Check power valves had the same type of thing happen.. One of the cables had pulled through and valve was not opening..
