I have no power going to the servo motor
![](/styles/admin.gif)
CDI, I have had this happen before.... shorted harness under motor I think took it out.
yup check your harness out..try a search on rub through,lots of posts.
put your year of your sled in your avatar also so we know..
You are right it was the CDI I switched from my 600 srx to my 700 srx,It is the same part number Thank You very much Paulieflyer 2
I zapped it with a homade tester without a fuse in the link "dummy me"
did ya check for a rub through so it don't take your CDI out again?
awesome ![Thumbs Up ;)! ;)!](https://totallyamaha.net/images/smilies/div20.gif)
paulieflyer2 said:You are right it was the CDI I switched from my 600 srx to my 700 srx,It is the same part number Thank You very much Paulieflyer 2
Are you shure I thought the 600 had two degrees more timing then the 700.
The part number is the same,it looks identicle
