CB rear skid drop brackets pro and cons?
I added mine when I went to the 144x16x2 paddle track and needed the tunnel clearance!
The only pro that I know of is it allows the suspension to drop down in the snow further before the running boards hang up. yea I guess it looks kewl too!
great product, but 5h!t for directions!
they need to supply a paper template for the center hole
I finally took my suspension back out
took a flat piece of metal marked & drilled the holes (frt hole to center hole)
bolted it in the front hole and pivot down the rear to fit the 1-1/2 template i made
redrilled the holes, ( did both sides this way to be perfectly even)
drilled out the rivets for the middle support plates and going to relocate them at the new drilled holes
installing track Monday night and will try suspension movement FIRST!!
