saskattakman
i am looking for better light for my 98 srx....i know the stockers are 55/60 can i get away installing a 90/100 if i install a led tailight bulb??? anybody know the wattage of a stock 1157 bulb???i am running a heated shield and handwarmers/thumbwarmers all the time...also has anybody run the blue 194 dash bulbs???
I ran one in my old 98 srx with a led tailight bulb, its was OK, but it will still dim down when you apply the brakes some, its not too bad, it did help alot.
saskattakman
thanks gonna give it a try just didnt want to melt any wiring or stator doin it.....
the one I used Kyle was a lockhart phillips, I recall it being a 80/100 watt.
SRXmathias
On cars the biggest issue with stronger bulbs is often that the plastic reflector could melt or be discolored, just a little something to think about!
I have been running a 85/100 bulb in my 99 for years with the led tail light. It does help alot, but when you switch beams it dims down real bad for a second. I was thinking of trying out a Phillips Crystalvision and see how that is.
I've been using a PIAA Xtreme White Plus 55/60 with the output equal to 100\110 with a led tailight for three years in my sx without a problem.One of the best upgrades I did on the sx.
