mountainx01
ok i dropped the skid to the lower hole in the tunnel, and i put a set off saddleless mnt skis on. sled ran great with these changes, no problem going through powder or climbing, but compared to other sled front is dragging on the ground. will a set of viper shock be the answer or could i go to a longer shock?
A K MtnViper
mountainx01 said:ok i dropped the skid to the lower hole in the tunnel, and i put a set off saddleless mnt skis on. sled ran great with these changes, no problem going through powder or climbing, but compared to other sled front is dragging on the ground. will a set of viper shock be the answer or could i go to a longer shock?
This should help
http://www.totallyamaha.com/snowmobiles/aaTECH/Suspension/specs/suspensionspecs.htm
Ski lift is not always a good thing, do a search, every question you have is answered here some place.
