cwarnar
When I was cold starting with the choke (Starter) open it would idle as if it was closed. But when I closed the choke the machine stalled. After a while I was able to drive it with the choke open, it almost seemed like the choke was reversed. On my return trip home giving the machine throttle it would stall. I tried changing Sparkplugs and checked the carb and everything looks okay.
I am going to put in a heated garage overnight and see if that does the trick… any advice?
