srx4life
I have an 01 srx 700 and the drive belt seems to be sitting too low in the secondary clutch. I have tried a new belt and the top of the belt sits flush with the top edge of the sec. I was wondering if this is where I should be sitting. To me it seems wrong. any suggestions and advice on what to do???? I am running stock spring with a hauck helix.
tedgoesfast
the the best it gets without belt squeling
daman said:With a new beld(8DN) it should ride bettween 0.5mm below to 1.5mm above
the secondary(in that area).
if not and your sitting to low from what your saying you need to remove the
secondary and pull out a shim washer from the three bolts on the back.
What he said ^^^ !!
As long as your center to center is correct, I like to set mine up so the track creeps while the rear end is up in the air.
srx4life
Thanks Daman, I have removed three washers already that were on the back side of the sec. From the spec sheets you posted it seems normal to me then.
Yup my bad left that out sorry..importaint too,may want to check.S.X. said:As long as your center to center is correct,
your probably good then, but i'd check cc some time
triple
S.X. said:What he said ^^^ !!
I bought a new belt, it sat just right in the secondary but squelled like crazy. I didn't check the center to center, but the belt would only push down like 1/2". I threw my old belt on and it was fine. Holding the 2 belts tight next to eachother, the new one was shorter???? Do they stretch that much???
is it a oem belt ??yamaha one
triple
modsrx said:is it a oem belt ??yamaha one
Yup. 8dn-17641....right from the dealer.
Yama49601
If it's too low you have to add spacers/shims, not take them out.
yes your right, my bad!!!!....need to add a shim, sorry srx4life, thanks Yama49601, had to tight in my head.Yama49601 said:If it's too low you have to add spacers/shims, not take them out.
but he's still with in spec so...
