8BV50 V.S. 8BV51 Roller Plate
B Rad
Yorkville,Il
I have a '98 Srx 700 that has had a roller plate in the secondary since new. Has worked absolutely flawless for 6800 miles.
Issues: The roller wheels broke apart recently as I was going over the sled. I have new wheels coming for the plate and while disassembling the clutch I noticed that the 8bv50 helix had got some minimal scuffing on the outside edges of the ramps. I think that I could file the out and smooth it down a little if this is acceptable?? It had been riding on the wheel pins that hold the wheels if you understand what I mean.
I also found a 8bv51 from a Sx-r700 that was laying around. Would it be better to use the 51 since it is new?? Or would this greatly affect performance?? I noticed that I just have a black spring and set at 3 on top and 3 on the bottom.
I checked the charts and didn't see this on there. I am not a cluth guru as I have never had to do anything to this.
Thanks for any help!!
