mopar1rules
anyone ever play with a boost bottle on a '00 or newer SRX? What kind of jetting changes did you have to make?
KatahdinLodge
boost bottle
Boost bottles do not usually require jetting. They dont change the air/fuel ratio, just store an air/fuel charge. Kinda like an expansion chamber (2-stroke pipe) but for the intake side.
Yama49601
You have a 98 700 an SRX and a Viper?
mopar1rules
i (josh) have a 02 viper and a 03 600ho rev. My buddy (craig---who keeps using my username) has a 98 srx 600, 00 700 srx, and 05 rev 800.
yamyrider
I know the bottle works for the non power valve tripples but never heard of one on a PV motor.
mopar1rules
so they do work then, I thought I read something once that they mainly help on the low end but a 3-4 hp gain can also be found on top. can anyone else confirm this? how about jetting? i'm also running a bender can and carbon fiber reeds and seem to be running unusually lean and had to jet way bigger on the mains. I sprayed carb clean all around to check for leaks and nothing turned up, or is that just the nature or the beast? cause I don't think a silencer, reeds, and boost bottle could change the flow of air through the engine that drasticly
