So who's going?
Here are a couple links:
http://www.cosdra.com/schedule.htm
http://www.tv7-4.com/news/news_story.aspx?id=82674
ExpertXViper
You know where in Gaylord this event is gunna be held??? What part of town?? Just curious cause if theres snow on the trails Ill diff. be up and have to check it out.
			Bushman
I caught that on the news this morning, Looks like the track is where they had the grass drags in years past behind the airport. Looks as if they removed some dirt so it could be flooded for the ice. Should be a good show the the area needs bad!
			Bushman said:I caught that on the news this morning, Looks like the track is where they had the grass drags in years past behind the airport. Looks as if they removed some dirt so it could be flooded for the ice. Should be a good show the the area needs bad!
If that's the case then the M-32 connector trail runs right behind the airport.
