Pipe mounting flange questions??
Sxr700Bandit
Triple Piped 700 Triple
S.E. Michigan
I am curious to know the diameter of the triple pipe mounting flanges for bender pipes because I need 2 pair of the sealing rings for my '95 600 that has twin GYT pipes. If the twin pipe flanges are the same diameter as the trip pipe flanges the next questions is where do I find the sealing rings? Are they just simply a pair of small bore piston rings?
I already called Bender and they said call back tomorrow and they will know more, but before this i got a - we discontinued those twin pipes years ago because we had too many problems with them...... I am thinking that I am in for a run for my money. Any help would be GREATLY appreciated. TIA. T
I will try and get ahold of the guy i got mine from last year and see what they where, i might have the paperwork too. I was thinking they where piston rings but don't remember exactly.
they are thicker than piston rings, about 1/8th inch maybe a little less.
I have ordered 3 or 4 different sets from bender in the last 2 years .
I have yet to recieve any.
Alright here is the Part number 888-14633-00-00
A little under $6 a ring 4(required)
Mike at DRH Specialty can order them for you thats where i got mine 651-437-4205
I called Justin @ Full Power Performance and he told me how bender use to make their sealing rings..... Duh, Why didn't I think of cutting down and using a piece of pipe.... T
P.S. I ordered the rings from where Braindead sent me. Thanks man!
Good to hear mikes a great guy and always hooks me up.
When you put them on I like to use hi temp sealant on the Flange and pipe then put them together to help seal it off all the way.
