Brun_SRX
I have put a sc-10 II suspension under my SRX last year so I got those ugly wheels... Do Yamaha idler and front wheels will fit and do they have the same diameter?
Brun_SRX
Anybody tried this before?
richierich
no yamaha ones are smaller.you can get plain black wheels aftermarket for that skid.
Brun_SRX
Thanks for the info
triple
How's the clutching on your sled now? Sorry... ![Offtopic :offtopic: :offtopic:](https://totallyamaha.net/images/smilies/offtopic.gif)
Brun_SRX
Well I didn't try any other setup as weather here was not good at all.... Also found another problem on the sled as pv's doesn't seem to fully open at WOT. Should explain why I had so many headaches trying to keep it revin over 8K. The fact is that they fully open with my homemade tester plugged on so I got a good adjustment, but doesn't go to the same distance while engine tries to turn the servo-motor WOT. Made the diagnostic test (idle under 900) and flashing light gave me the code that somethings wrong with that servo-motor. I also had that blinkin light while riding but thought it was a bad temp sensor. So as the servo fully open while I apply 12V on the tester, and isn't working while the engine running, guess it's the cdi unit or something electrical. BTW if anybody had that trouble please help me!
So as you see, need to check this out before changing anything else....
