gofastforfun
ok I need some help guys,the sled starts perfect,idles fine,but wont get over 4500-5000 rpm.Takes off fine out of the hole and then falls flat on its face.Stays running on both cylinders ,but no power.Its not in the carbs as I have replaced them.Also has new plugs,pistons,rings,good compression.Could it be the stator???? Help!!!
