Spark Plug Question
i've always wondered the differences of all the plug names too, so i searched it on google.
i found this on the NGK site, i cant really follow it that well, but i think the ecs has a low angle ground electrode, where the es doesnt, im not exactly sure what that means, but if someone else does, maybe they can help us out
http://www.ngksparkplugs.com/docs/tech/partnumberkey.pdf
The difference is in the electrode design. The BRxxES has an elcetrode that protrudes below the threaded portion of the plug, call it like a normal spark plug, and the BRxxECS has the electrode inset into the plug deeper than the other plug. If you compare the two plugs side by side and look carefully you will notice the difference. T
