Exciter II sx cylinder chipped ok to use???? pls advise
fish6107
ontario
I have a used cly i want to use BUT there is a chip near the top of the cyl and i am wanting to get opinions. Currently i went to 2 yammie dealers and they said it should be fine as the rings won't hit it BUT i would like some more opinions to make sure what i decide will be fine. So pls offer any thoughts on this.... :letitsnow
fish6107
fish6107
the problem would be detention the rings would not hit the spot but it could possibly keep chiping due to developing a hot spot on the edges of the chip
so i guess i should call the scrap yard i got it from and see if they have another one... the only thing that sucks it it will require me to drive one way of 250 km.. oh well i sure don't want to get it back together and have it explode again....
THANK YOU! for you honset opinion!!!
One question for you though have you ever heard of having a nickasyl cyl honed befor reasembling them? i have seen conflicting reports about having a used nicacyl honed befor reasmbling.... just wondering....
nic cyl's can be honed,use a 3 stone spring flex hone 240-280 grit
don't use a ball hone.
nic is very hard so a hone won't do much but you can atleast cut some
of the glaze..
