Secondary sheaves alignment with each other?
Yama49601
Cadillac, Michigan
Does it matter how you put the secondary together? Do the holes that are drilled for balancing (if that's what they are even for) need to be lined up or anything like that? I just took mine all apart and thoroughly cleaned it but I forgot to mark the sheaves for reassembly.
No, they are balanced individually. You can put them on opposite each other is what I did, no issues to date…cheers
