Hey guys I was just wondering how many plates on the stock chain of the 01 SRX? Is it a 11, 13 or 15? I am looking to gearing down one tooth on top and need to know so I can order my gear.
bluehammer
It's 13 link. The 98's`and 99's were 15 link
YAMMIEGOD3:16
13 wide. 3:16 (yammie tony)
thats hyvo chain, not just 13 plate std chain. The hyvo chain is used in the srx's and vipers from 2000-03 its a differnt chain then the old 13 wide std. in the sx,sxr's.
so if I order a 13 wide sprocket it should fit on the stock chain?
as long as its "hyvo"
I don't know the sled is bone stock everything. but I guess I will have to pull the chain case appart to find out. Why is there a different chain in in the 2001 srx? was there a choice of chain?
YAMMIEGOD3:16
DEPENDS ON GEARS AND RATIO. STOCK ON 01 SRX WAS 23-38. THAT WOULD USE THE 70 LINK. PRETTY MUCH WHEN YA START DROPING TOP GEAR, YOU NEED THE 68 LINK. REMEMBER THIS MACHINE USES HYVO GEARS AND CHAIN. ! 3:16 (yammie tony)
Why did the 98-99's have a 15 wide? Were they HYVO? Just wondering why the change in chain from the 98-99 to 00-02. Also, what is HYVO or what does it stand for? Thanks.
did the 2001 come stock with the HYVO chain?
800
Yes it does, Yammie god gave you the correct info
Roost 'Er
im running 22-38 and it runs good tops out around 105-110mph... but pulls hard getting there, no complaints here
YAMMIEGOD3:16
KEEP IN MIND BY 2000 YAMAHA WAS STARTING TO TRY AND LITE,EN THE SRX UP. 13 WIDE GEARS, LIGHTER BRAKE ROTAR ( 01 srx ) LIGHTER FLY WHEEL. etc. 3:16 (yammie tony)
PhatboyC
YAMMIEGOD3:16 said:KEEP IN MIND BY 2000 YAMAHA WAS STARTING TO TRY AND LITE,EN THE SRX UP. 13 WIDE GEARS, LIGHTER BRAKE ROTAR ( 01 srx ) LIGHTER FLY WHEEL. etc. 3:16 (yammie tony)
It could also be for less rotational mass to lose less in power transfer. The 00 was the first year they claim better performances than the year before. Only in 01 did they start advertising the lighter parts. Correct me if I'm wrong, I'm still a newbie here.
YAMMIEGOD3:16
ONLY THING THE 00 HAD WAS THE 98-99 BRAKE ROTOR, OTHER WISE SAME AS 01. 3:16 (yammie tony)
