Viper Heat Exchanger Swap Help!
jdp1under
ct
Hey Guys I Have To Change My Brake Side Running Board Exchanger Its Leaking A Little From The Top (in Between The Running Board And Exchanger) I Bought This Sled With The Rear Cooler And Was Wondering A Bleeding Proceedure Before I Dig In To It! Thanks Also Any Recomendations On The Rivots Steel Aluminum? Thanks
Just R&R the exchanger and bleed it at the rear exchanger, you may have to do it more than once since you're gonna drain most of the system. As far as the rivets go I would use the factory rivets, they're pretty tough, and the exchanger is a structural part of the sled.
