Transfer rods!!!
fasteddie
Canada
Finally got my viper rods installed on my SXR700, "WOW" an absolute must. I started out with a 20mm sliding gap and Took it for a test run. What a difference skis come up and stay up as long as you hold it to the pin. I set the track to the same tension as before and with the new hook up it was ratcheting like crazy so I closed the gap by maybe 2or3mm and its only ratcheting a little now. I guess I will have to tighten the track a bit. I did notice a change in the ride, Its a bit like a pogo stick now. Too much transfer?
