Picture below is from SLP instructions. Why have they suggested two different needle setting and which one should I be using? I don't understand what the difference is. FYI - I'm between 0-3000'.
Right now I think it setup: (SNOWRULES please correct me if I'm wrong)
Fuel Screw @ 1-3/4
Stock needle @ clip position 4
Main @ 162.5
Fuel Screw @ 1-3/4
Main @ 162.5
SNOWRULES
ya that's right
Yama49601
YamerDown said:What are these parts in the picture below? I assume they are 3 main jets and three pilot jets?
Definitely pilot jets and looks like main jets to me too.
Yama49601
The different needle settings are for different temps. Above 0 degrees is 4th position using the stock main nozzle/needle jet and below 0 degrees it should be set at 3.5 according to that using a Q0 nozzle/needle jet (For 0-3000 feet).
